Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
To begin the removal of your back panel, first locate the lift tab on the bottom-right corner.
Next, gently slide your thumb (or plastic tool if you prefer) down the seem running the length of your Blu Studio until the rear panel is completely removed.
Your rear panel should be placed nearby and in a safe location until you are finished with your task.
Look at the sticker on top of the battery housing and note the model, part number and type.
Research this information to find out if you have an unlocked version of the phone.
If necessary slide the unneeded SIM card out of it's slot.
Take the front end tip of the SIM card (the side with the corner cut) and slide it gently into the SIM card slot.
Turn on your Studio 6.0 and test it to make sure that everything is working.
If your phone gives you an error, check your SIM card installation. If everything seems to be correct make sure your SIM card is activated.
If everything is working you're good to go.
7 farklı kişi bu kılavuzu tamamladı.
13 Yorum
Okay so my Sim has been working for months just 2 days ago my phone wouldn't turn on and then we'll now it doesn't read the Sim card idk what's going on with this but its getting annoying
i know i am having the same issue. it is saying my sim card is off and to turn it on
Its saying my Sim card is off..how do I turn it on.
I just got this phone and I install the sim card like they say and it still says no sim card
