Ana içeriğe geç
Blu Studio Selfie Battery Replacement
Neye ihtiyacın var
  1. Blu Studio Selfie Battery Replacement, Rear Cover: adım 1, 1 resimden 1.
    • Make sure your phone is powered off.
    • Turn the front of the phone away from you.
    • Run your fingers along the sides of the phone to identify where the case can be pulled apart.
  2. Blu Studio Selfie Battery Replacement: adım 2, 1 resimden 1.
    • Insert the flat end of your plastic opening into the crevice you found along the side of the phone.
    • Gently apply pressure until you feel the back case pop free of the phone.
    • Continue the previous two steps around the rest of the phone until the case is fully removed.
  3. Blu Studio Selfie Battery Replacement, Battery: adım 3, 2 resimden 1. Blu Studio Selfie Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Identify the crevice at the bottom of the battery.
    • There should be enough space for you to fit your fingernail between the battery and the phone.
    • Gently lift the battery free of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Stacy Kam
630 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 10-1, Remmell Spring 2016 USF Tampa, Team 10-1, Remmell Spring 2016 üyesi
USFT-REMMELL-S16S10G1
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 1,367
