Ana içeriğe geç
Bu Teardown'da Kullanılan Aletler
Bu teardown bir tamir kılavuzu değildir. Bluetooth earphone cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
    • with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
  2. using some thin tool separate the earphone case to expose the speaker just separate it a little wait for the next step
    • using some thin tool separate the earphone case
    • to expose the speaker just separate it a little wait for the next step
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. with the sharp pliers cut away the plastic around the speaker just half way push back the black part to have more room to work
    • with the sharp pliers cut away the plastic around the speaker just half way
    • push back the black part to have more room to work
  5. take off they cover after cutting it with a blade take off the white foam
    • take off they cover after cutting it
    • with a blade take off the white foam
    • after this step the whole earphones should be exposed
Jose A. Loza
331 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Hi Jose, did you happen to see the Bluetooth chip used in this product ?
Rajesh Gunasekaran - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 8
Son 30 Gün: 41
Her zaman: 894
