Neye ihtiyacın var
with some thin pliers or a blade pry open the button case the 2 pieces should come off with easy
using some thin tool separate the earphone case
to expose the speaker just separate it a little wait for the next step
with the sharp pliers cut away the plastic around the speaker just half way
push back the black part to have more room to work
take off they cover after cutting it
with a blade take off the white foam
after this step the whole earphones should be exposed
Bir Yorum
Hi Jose, did you happen to see the Bluetooth chip used in this product ?
what is a chip used? (below battery I guess)
Nemo - Yanıt
