Bu çeviri, kaynak kılavuzdaki en son güncellemeleri yansıtmayabilir. Çeviriyi güncellemeye yardımcı olun veya kaynak kılavuzunu görüntüleyin.
Giriş
Bodum Bistro B.Over 咖啡機 (型號 11001) 溫度保險絲更換
Neye ihtiyacın var
電源燈號有亮,但是沒有開始煮,或是煮到一半水位停止下降。
打開底座後,可以先嘗試測量電源的白色中性線跟加熱器下方的接頭之間的電阻,如果溫度保險絲燒掉,這兩個點會呈現斷路。加熱器的接頭在接地的鐵板後方,要技巧性的繞過去量。
如果電源燈無法打開,最有可能的是其中一個微動開關故障。共有兩個微動開關,一個用來偵測水位,另外一個是確定壺有在座上。微動開關故障可以嘗試用接點清潔劑噴了後,按壓開關清潔看看。
再量一下溫度保險絲。可以從電源中性線跟加熱管的下方接頭之間量,或是直接測量矽膠套管中拆出來的溫度保險絲兩端。
通路表示保險絲正常,斷路則是已經燒毀。溫度保險絲燒斷後不能復歸,只能更換。
原廠使用的溫度保險絲是攝氏172度120V/15A的規格。但是一般來說,可以找到15A以上的攝氏172度保險絲即可相容。這邊用的是 SF169E 這個型號,攝氏172度 250V/15A。
保險絲的兩端是用壓接的方式,可以嘗試從側邊夾鬆之後拔出電極,或是剪開保留一小段長度,用另一個壓接環接上。
新的保險絲壓上之後,要稍微扭轉拉拔看看有沒有壓接確實。
再量一次,確認通路後進行固定。固定扣的螺帽本身是滑動的,需要用尖嘴箝夾住,才能將螺絲鎖緊。
鎖緊之前可以先用手電筒或是觸摸的方式確認溫度保險絲有在固定扣的正中央。
重新組裝步驟僅列出關鍵步驟,其餘請參考拆開流程
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
96%
C Yang dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
2 Yorum
Have the older version of this Coffee Maker changing the thermal cutoff fuse as above did NOT resolve my issues. (Coffee maker would get HOT very HOT and cutoff/flashing RED light, Some steam but i noticed little water passing up tubes.) A strong sharp blow down both white rubber tubes/pipes (when machine is COLD! seen in step 6) did however fix my issue. (& now it has a new thermal cutoff fitted also) Just cleaning it out now with white vinegar/water solution. Hope this helps someone else.
Thank you for the detailed instructions. My Bodum coffee maker has the same symptom of blinking LED and not heating up, but the fuse was not blown. The heating coils have the expected impedance. What other component could be the culprit? Thanks.
