Ana içeriğe geç
Body Panel Removal
Neye ihtiyacın var
  1. Body Panel Removal, Remove film door: adım 1, 1 resimden 1.
    • Push down the latch to release the film door.
    FixBot'a Sor
    Yorum Ekle
  2. Body Panel Removal, Remove top cover screws: adım 2, 3 resimden 1. Body Panel Removal, Remove top cover screws: adım 2, 3 resimden 2. Body Panel Removal, Remove top cover screws: adım 2, 3 resimden 3.
    • Remove two 7.5 mm #00 screws.
    • Remove one 9.0 mm #00 screw.
    • Remove one 13.5 mm #00 screw from inside the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  3. Body Panel Removal, Remove top cover screws: adım 3, 3 resimden 1. Body Panel Removal, Remove top cover screws: adım 3, 3 resimden 2. Body Panel Removal, Remove top cover screws: adım 3, 3 resimden 3.
    • Push the button to pop up the flash.
    • Remove one 3.5 mm #00 screw.
    • Remove one 5.5 mm #00 screw.
    FixBot'a Sor
    Yorum Ekle
  4. Body Panel Removal, Lift top cover: adım 4, 1 resimden 1.
    • Carefully lift the top cover away from the body to access wired connections.
    • The top cover is still connected in several locations.
    FixBot'a Sor
    Yorum Ekle
  5. Body Panel Removal, Access flash connections: adım 5, 2 resimden 1. Body Panel Removal, Access flash connections: adım 5, 2 resimden 2.
    • Peel back the corner of the rubber grip.
    • Remove the small plastic cover.
    • Be careful not to short the wires before the flash capacitors have been properly discharged.
    FixBot'a Sor
    Yorum Ekle
  6. Body Panel Removal, Discharge flash capacitors: adım 6, 1 resimden 1.
    • Use a 1kΩ-10kΩ high power resistor to discharge the capacitor. Place the resistor between the blue wire, exposed in the previous step, and ground.
    • The flash capacitors store energy at a very high voltage. Failing to discharge the capacitors properly could result in personal injury and/or damage to the camera.
    FixBot'a Sor
    Yorum Ekle
  7. Body Panel Removal, Disconnect right flex cable: adım 7, 1 resimden 1.
    • Carefully lift the sides of the white latch.
    • Hold the flex PCB on the camera body in place as you lift to prevent damaging the flex.
    FixBot'a Sor
    Yorum Ekle
  8. Body Panel Removal, Disconnect left flex cable: adım 8, 1 resimden 1.
    • Desolder the red wire.
    FixBot'a Sor
    Yorum Ekle
  9. Body Panel Removal, Desolder flash connections: adım 9, 2 resimden 1. Body Panel Removal, Desolder flash connections: adım 9, 2 resimden 2.
    • Desolder blue, black, brown and green wires.
    • Remove the loose shim washer if present.
    FixBot'a Sor
    Yorum Ekle
  10. Body Panel Removal, Desolder the flash flex cable: adım 10, 2 resimden 1. Body Panel Removal, Desolder the flash flex cable: adım 10, 2 resimden 2.
    • Remove the piece of cellophane tape covering the flex connections.
    • Desolder flex connetions.
    FixBot'a Sor
    Yorum Ekle
  11. Body Panel Removal, Remove bottom cover: adım 11, 3 resimden 1. Body Panel Removal, Remove bottom cover: adım 11, 3 resimden 2. Body Panel Removal, Remove bottom cover: adım 11, 3 resimden 3.
    • Use isopropyl alcohol to soften the adhesive under the country plate and remove.
    • Remove one 5mm #00 screw.
    • Remove one 7.5mm #00 screw.
    • Remove two 4.5mm #00 screws.
    • Remove one 5.5mm #00 screw.
    • Remove the plastic frame around the accessory grip contacts.
    • Reassembly Note: The camera can be checked for functionality at this point. Install the rear door, insert a fresh pair of batteries and try to fire the shutter.
    FixBot'a Sor
    Yorum Ekle
  12. Body Panel Removal, Remove front left cover: adım 12, 1 resimden 1.
    • Remove one 4.0 mm #00 screw.
    • Remove left cover.
    FixBot'a Sor
    Yorum Ekle
  13. Body Panel Removal, Remove front cover: adım 13, 1 resimden 1.
    • Remove front cover.
    FixBot'a Sor
    Yorum Ekle
  14. Body Panel Removal, Unscrew front right cover: adım 14, 3 resimden 1. Body Panel Removal, Unscrew front right cover: adım 14, 3 resimden 2. Body Panel Removal, Unscrew front right cover: adım 14, 3 resimden 3.
    • Remove one 6.0 mm #00 screw.
    • Remove two 3.5 mm #00 screws.
    • Remove one 5.0 mm #00 screw.
    • Remove the strap lug.
    FixBot'a Sor
    Yorum Ekle
  15. Body Panel Removal, Remove the front right cover: adım 15, 1 resimden 1.
    • Carefully pull the right panel away from the body. It is still attached.
    • Desolder the flex connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Sam Gustafson
11.000 İtibar
78 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 45
Her zaman: 581
