Ana içeriğe geç
Bomann DB 774CB Iron
Neye ihtiyacın var
  1. Bomann DB 774CB Iron, Startup: adım 1, 1 resimden 1.
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: adım 2, 3 resimden 1. Bomann DB 774CB Iron, Undressing the handle: adım 2, 3 resimden 2. Bomann DB 774CB Iron, Undressing the handle: adım 2, 3 resimden 3.
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: adım 3, 2 resimden 1. Bomann DB 774CB Iron, Stripping of the sole: adım 3, 2 resimden 2.
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: adım 4, 1 resimden 1.
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Sonuç
Putting each screw back in its place is no problem.
6 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
HelloMacOS dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Louis Possoz
459 İtibar
3 adet Kılavuz yazıldı
Ekip
Repair Café Louvain-la-Neuve Repair Café Louvain-la-Neuve üyesi
Local Repair Groups
2 Üyeler
13 adet Kılavuz yazıldı
1Rehber Yorum
Do you instructions in English
Nur Haque - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 16
Son 30 gün: 32
Her zaman: 3,296
