Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide will provide the steps to access the internal components including the motherboard where the copper button plates are located.
  1. On the back of the device, remove the four 3/8"  Torx head screws using the T-6 Torx bit. A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
    • On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
    • A Torx bit is the piece that is inserted into a bit driver, also known as a screw driver.
  2. Remove the stylus if it is in the housing at the top of the device. Turn the device so you are looking at it from the top down. Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
    • Remove the stylus if it is in the housing at the top of the device.
    • Turn the device so you are looking at it from the top down.
    • Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
  3. Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device. Remove the front face plate by pulling it straight up. The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
    • Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
    • Remove the front face plate by pulling it straight up.
    • The unlock switch on the device's side might come off while undoing the internal snaps or removing the face plate. This is perfectly normal.
  4. Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place. Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
    • Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
  5. With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard. With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
    • With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
  6. Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard. Remove the battery hidden behind the motherboard.
    • Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
    • Remove the battery hidden behind the motherboard.
  7. Using tweezers gently go around the edges of the copper plate to remove the adhesive. Using tweezers gently go around the edges of the copper plate to remove the adhesive.
    • Using tweezers gently go around the edges of the copper plate to remove the adhesive.
  8. Use tweezers to grip the outer edge of the copper plate and lift the button straight off. Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
    • Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
Sonuç
Gareth
384 İtibar
3 adet Kılavuz yazıldı
Takım
CSU Fullerton, Team 2-6, Bruce Fall 2014 CSU Fullerton, Team 2-6, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,388
