Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
On the back of the device, remove the four 3/8" Torx head screws using the T-6 Torx bit.
Remove the stylus if it is in the housing at the top of the device.
Turn the device so you are looking at it from the top down.
Using your thumbs on each wall of the stylus housing, open the frame of the device by gently pulling the two sides apart.
Insert a spudger into the seam between the front and back plates of the frame. Unsnap the snaps around the entire frame of the device.
Remove the front face plate by pulling it straight up.
Use a spudger (or gently bend the back plate of the device) to unsnap the snaps holding the screen in place.
With a spudger, press against the lip of the connector closest to the wires to remove the battery connector from the motherboard.
Gently lift the motherboard with a spudger or small object by inserting it in the seam between the back frame and the motherboard.
Remove the battery hidden behind the motherboard.
Using tweezers gently go around the edges of the copper plate to remove the adhesive.
Use tweezers to grip the outer edge of the copper plate and lift the button straight off.
