Ana içeriğe geç
Boombotix Boombot Mini Speaker Replacement
Neye ihtiyacın var
  1. Boombotix Boombot Mini Speaker Replacement, Speaker: adım 1, 3 resimden 1. Boombotix Boombot Mini Speaker Replacement, Speaker: adım 1, 3 resimden 2. Boombotix Boombot Mini Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Twist the front panel of the speaker to the left.
    • Do not try to pry or pop off the front panel.
  2. Boombotix Boombot Mini Speaker Replacement: adım 2, 3 resimden 1. Boombotix Boombot Mini Speaker Replacement: adım 2, 3 resimden 2. Boombotix Boombot Mini Speaker Replacement: adım 2, 3 resimden 3.
    • Take out the four screws, then remove the panel that contains the speaker.
  3. Boombotix Boombot Mini Speaker Replacement: adım 3, 3 resimden 1. Boombotix Boombot Mini Speaker Replacement: adım 3, 3 resimden 2. Boombotix Boombot Mini Speaker Replacement: adım 3, 3 resimden 3.
    • Take the speaker off of the base.
    • Expose the motherboard and place the speaker next to it.
    • Be careful not to tangle or damage the wires connecting the speaker.
    • This panel will be harder to get off. Use something small such as a card to creat a lip for leverage.
  4. Boombotix Boombot Mini Speaker Replacement: adım 4, 1 resimden 1.
    • Find the connection of the speaker by following the wires.
    • Do not damage the battery. Make sure not to use any metal object to poke around in the device because of possible shock.
  5. Boombotix Boombot Mini Speaker Replacement: adım 5, 2 resimden 1. Boombotix Boombot Mini Speaker Replacement: adım 5, 2 resimden 2.
    • Now that you have found the wire connection to the motherboard, disconnect it.
    • Pull the wire straight out.
  6. Boombotix Boombot Mini Speaker Replacement: adım 6, 1 resimden 1.
    • Connect the white plug of the new speaker to the motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 1,408
