Ana içeriğe geç
Boosted Board 1st Generation Belts Replacement
Neye ihtiyacın var
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: adım 1, 2 resimden 1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: adım 1, 2 resimden 2.
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
    FixBot'a Sor
    Yorum Ekle
  2. Boosted Board 1st Generation Belts Replacement: adım 2, 1 resimden 1.
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
    FixBot'a Sor
    Yorum Ekle
  3. Boosted Board 1st Generation Belts Replacement: adım 3, 2 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 3, 2 resimden 2.
    • Remove the axel nut with a 1/2" socket wrench
    FixBot'a Sor
    Yorum Ekle
  4. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 2. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 3.
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
    FixBot'a Sor
    Yorum Ekle
  5. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 1. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 2. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 3.
    • Compress the motor mount back .
    • Slide the belt off the axle
    FixBot'a Sor
    Yorum Ekle
  6. Boosted Board 1st Generation Belts Replacement: adım 6, 1 resimden 1.
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
    FixBot'a Sor
    Yorum Ekle
  7. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 2. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 3.
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Emily Imfeld
532 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G7
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 40
Her zaman: 2,043
