Ana içeriğe geç
Boosted Board 1st Generation Belts Replacement
Neye ihtiyacın var
  1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: adım 1, 2 resimden 1. Boosted Board 1st Generation Belts Replacement, Rear Wheels: adım 1, 2 resimden 2.
    • Loosen the two 16.74 mm motor mount hex nut screws with a 9/64" Allen wrench.
    • Do Not Remove the Screws.
  2. Boosted Board 1st Generation Belts Replacement: adım 2, 1 resimden 1.
    • Compress the motor mount back towards the wheel.
    • While keeping the motor mount compressed, tighten one of the hex nuts that you loosened in the previous step.
    • The motor mounts are spring tensioned so it is necessary compress them to loosen the belts.
  3. Boosted Board 1st Generation Belts Replacement: adım 3, 2 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 3, 2 resimden 2.
    • Remove the axel nut with a 1/2" socket wrench
  4. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 2. Boosted Board 1st Generation Belts Replacement: adım 4, 3 resimden 3.
    • Rotate and pull counterclockwise until the wheel comes off the axle completely.
    • The front washer will come off with the wheel.
    • Remove the back washer from the axle.
    • Replacing the wheel requires the bearings to be switched into the new wheel.
  5. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 1. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 2. Boosted Board 1st Generation Belts Replacement, Belts: adım 5, 3 resimden 3.
    • Compress the motor mount back .
    • Slide the belt off the axle
  6. Boosted Board 1st Generation Belts Replacement: adım 6, 1 resimden 1.
    • Remove the two hex screws.
    • Remove the front hex screw.
    • When removing the Front hex screw, hold the motor mount and the truck together.
    • The springs inside the motor mount will push the motor out of the casing if they are not held together.
  7. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 1. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 2. Boosted Board 1st Generation Belts Replacement: adım 7, 3 resimden 3.
    • Making sure to hold the motor and truck together, lift off the belt casing and take off the belt.
    • Do Not let go of the motor and truck until the new belt is on and the Front hex screw is tightened securely.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Emily Imfeld
532 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-7, Livingston Fall 2016 Cal Poly, Team 15-7, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G7
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 1,767
