Ana içeriğe geç
Boosted Mini Belt Replacement
Neye ihtiyacın var
  1. Boosted Mini Belt Replacement, Belt: adım 1, 2 resimden 1. Boosted Mini Belt Replacement, Belt: adım 1, 2 resimden 2.
    • Unscrew the axle nut holding the wheel in place with your wrench on the side of the board where the belt has snapped/became worn.
    FixBot'a Sor
    Yorum Ekle
  2. Boosted Mini Belt Replacement: adım 2, 2 resimden 1. Boosted Mini Belt Replacement: adım 2, 2 resimden 2.
    • Take off the nut and the washer.
    FixBot'a Sor
    Yorum Ekle
  3. Boosted Mini Belt Replacement: adım 3, 3 resimden 1. Boosted Mini Belt Replacement: adım 3, 3 resimden 2. Boosted Mini Belt Replacement: adım 3, 3 resimden 3.
    • Use your allen wrench to remove the two black motor cap screws on the motor counter clockwise.
    FixBot'a Sor
    Yorum Ekle
  4. Boosted Mini Belt Replacement: adım 4, 1 resimden 1.
    • Remove the plastic motor cap.
    FixBot'a Sor
    Yorum Ekle
  5. Boosted Mini Belt Replacement: adım 5, 3 resimden 1. Boosted Mini Belt Replacement: adım 5, 3 resimden 2. Boosted Mini Belt Replacement: adım 5, 3 resimden 3.
    • Use your allen wrench to loosen the four motor screws on the motor by turning your tool ¼ turn left. The motor should be loose.
    FixBot'a Sor
    Yorum Ekle
  6. Boosted Mini Belt Replacement: adım 6, 3 resimden 1. Boosted Mini Belt Replacement: adım 6, 3 resimden 2. Boosted Mini Belt Replacement: adım 6, 3 resimden 3.
    • Remove the wheel and belt (if not snapped off already).
    FixBot'a Sor
    Yorum Ekle
  7. Boosted Mini Belt Replacement: adım 7, 2 resimden 1. Boosted Mini Belt Replacement: adım 7, 2 resimden 2.
    • Make sure the axle spacer and drive pulley washer are still in place on the axel.
    FixBot'a Sor
    Yorum Ekle
  8. Boosted Mini Belt Replacement: adım 8, 3 resimden 1. Boosted Mini Belt Replacement: adım 8, 3 resimden 2. Boosted Mini Belt Replacement: adım 8, 3 resimden 3.
    • Get your new Boosted belt and place it on the inner side drive pulley of the wheel.
    FixBot'a Sor
    Yorum Ekle
  9. Boosted Mini Belt Replacement: adım 9, 2 resimden 1. Boosted Mini Belt Replacement: adım 9, 2 resimden 2.
    • Place the wheel with its new belt inner side first on the axle, making sure the belt is securely back over the motor pulley.
    FixBot'a Sor
    Yorum Ekle
  10. Boosted Mini Belt Replacement: adım 10, 1 resimden 1.
    • To tighten the belt, create tension by putting your thumb on the wheel of the board and your fingers on the motor and pull the motor towards the motor driver until the belt is taught. There should be some flex in the belt after tightening.
    FixBot'a Sor
    Yorum Ekle
  11. Boosted Mini Belt Replacement: adım 11, 2 resimden 1. Boosted Mini Belt Replacement: adım 11, 2 resimden 2.
    • Using the allen wrench place the two screws furthest from the wheel first back in place and tighten, then tighten the closer two screws.
    FixBot'a Sor
    Yorum Ekle
  12. Boosted Mini Belt Replacement: adım 12, 3 resimden 1. Boosted Mini Belt Replacement: adım 12, 3 resimden 2. Boosted Mini Belt Replacement: adım 12, 3 resimden 3.
    • Place the axle washer and nut back on the axle.
    • Make sure that the axle washer is first, closest to the wheel, then the nut.
    FixBot'a Sor
    Yorum Ekle
  13. Boosted Mini Belt Replacement: adım 13, 1 resimden 1.
    • Use your wrench to turn the nut clockwise to tighten it.
    FixBot'a Sor
    Yorum Ekle
  14. Boosted Mini Belt Replacement: adım 14, 1 resimden 1.
    • Place the plastic motor cap on the motor.
    FixBot'a Sor
    Yorum Ekle
  15. Boosted Mini Belt Replacement: adım 15, 3 resimden 1. Boosted Mini Belt Replacement: adım 15, 3 resimden 2. Boosted Mini Belt Replacement: adım 15, 3 resimden 3.
    • Lastly, use the allen wrench to reinstall the two motor cap screws.
    FixBot'a Sor
    Yorum Ekle
Sonuç
If the belt on the other side of the skateboard also needs to be replaced, repeat steps 1-16.
Bir başkası bu kılavuzu tamamladı.
Juliana Renert
241 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-1, Andersen Winter 2024 UC Davis, Team 4-1, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S4G1
3 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 33
Her zaman: 419
