Ana içeriğe geç
Boot Zipper Replacement
Neye ihtiyacın var
  1. Boot Zipper Replacement, Zipper: adım 1, 2 resimden 1. Boot Zipper Replacement, Zipper: adım 1, 2 resimden 2.
    • Using a seam ripper, carefully remove the stitching at the top of the boot on either side of the zipper.
    • Only remove enough to free the zipper, about ¾ of an inch.
    FixBot'a Sor
    Yorum Ekle
  2. Boot Zipper Replacement: adım 2, 3 resimden 1. Boot Zipper Replacement: adım 2, 3 resimden 2. Boot Zipper Replacement: adım 2, 3 resimden 3.
    • Remove the stitching on the heel side of the zipper.
    • The stitches on the heel side connect four layers of material: the lining, the zipper underlay, the zipper, and the outer leather.
    • Work between the leather and the zipper by pulling apart the leather and zipper and inserting the seam ripper into the gap.
    FixBot'a Sor
    Yorum Ekle
  3. Boot Zipper Replacement: adım 3, 2 resimden 1. Boot Zipper Replacement: adım 3, 2 resimden 2.
    • Remove the stitching on the toe side of the zipper.
    • The stitches on the toe side connect three layers of material: the lining, the zipper, and the outer leather.
    • Set aside the original zipper.
    FixBot'a Sor
    Yorum Ekle
  4. Boot Zipper Replacement: adım 4, 1 resimden 1.
    • Remove any leftover thread.
    FixBot'a Sor
    Yorum Ekle
  5. Boot Zipper Replacement: adım 5, 2 resimden 1. Boot Zipper Replacement: adım 5, 2 resimden 2.
    • Measure your zipper against the boot.
    • Use a pin to mark how long it should be.
    FixBot'a Sor
    Yorum Ekle
  6. Boot Zipper Replacement: adım 6, 1 resimden 1.
    • If your zipper is too long, trim it about an inch below your pin.
    FixBot'a Sor
    Yorum Ekle
  7. Boot Zipper Replacement: adım 7, 2 resimden 1. Boot Zipper Replacement: adım 7, 2 resimden 2.
    • Fold down the excess fabric at the top of the zipper twice to create a right angle.
    FixBot'a Sor
    Yorum Ekle
  8. Boot Zipper Replacement: adım 8, 3 resimden 1. Boot Zipper Replacement: adım 8, 3 resimden 2. Boot Zipper Replacement: adım 8, 3 resimden 3.
    • Stitch in place.
    • Use pliers if the fabric is too thick to push the needle through easily.
    FixBot'a Sor
    Yorum Ekle
  9. Boot Zipper Replacement: adım 9, 2 resimden 1. Boot Zipper Replacement: adım 9, 2 resimden 2.
    • Pin your new zipper to the outer leather on the heel side.
    • Be careful to put your pins through the existing holes in the leather to avoid damaging the leather further.
    FixBot'a Sor
    Yorum Ekle
  10. Boot Zipper Replacement: adım 10, 1 resimden 1.
    • Using a backstitch, sew the zipper to the leather along the inner row of stitching.
    • Be careful to put your needle through the existing holes in the leather to avoid damaging the leather further.
    FixBot'a Sor
    Yorum Ekle
  11. Boot Zipper Replacement: adım 11, 2 resimden 1. Boot Zipper Replacement: adım 11, 2 resimden 2.
    • Repeat steps 8 and 9 for the toe side of the zipper.
    FixBot'a Sor
    Yorum Ekle
  12. Boot Zipper Replacement: adım 12, 2 resimden 1. Boot Zipper Replacement: adım 12, 2 resimden 2.
    • Pin the lining to the zipper and leather on the toe side.
    FixBot'a Sor
    Yorum Ekle
  13. Boot Zipper Replacement: adım 13, 2 resimden 1. Boot Zipper Replacement: adım 13, 2 resimden 2.
    • Using a backstitch, sew the lining into place along the outer row of stitching.
    FixBot'a Sor
    Yorum Ekle
  14. Boot Zipper Replacement: adım 14, 2 resimden 1. Boot Zipper Replacement: adım 14, 2 resimden 2.
    • Pin the lining and zipper underlay to the zipper and outer leather on the heel side.
    FixBot'a Sor
    Yorum Ekle
  15. Boot Zipper Replacement: adım 15, 1 resimden 1.
    • Using a backstitch, sew the lining and zipper underlay into place along the outer row of stitching.
    FixBot'a Sor
    Yorum Ekle
  16. Boot Zipper Replacement: adım 16, 2 resimden 1. Boot Zipper Replacement: adım 16, 2 resimden 2.
    • This should be the final outcome after you repair the boot.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
Alex
258 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 UC Davis, Team 4-2, Vidal-Chiesa Fall 2024 üyesi
UCD-VIDAL-CHIESA-F24S4G2
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 32
Son 30 gün: 118
Her zaman: 2,823
