Ana içeriğe geç
Bosch 3727DEVS Governor Replacement
Neye ihtiyacın var
  1. Bosch 3727DEVS Governor Replacement, Governor: adım 1, 3 resimden 1. Bosch 3727DEVS Governor Replacement, Governor: adım 1, 3 resimden 2. Bosch 3727DEVS Governor Replacement, Governor: adım 1, 3 resimden 3.
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top off of the sander.
  2. Bosch 3727DEVS Governor Replacement: adım 2, 3 resimden 1. Bosch 3727DEVS Governor Replacement: adım 2, 3 resimden 2. Bosch 3727DEVS Governor Replacement: adım 2, 3 resimden 3.
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift the cable clip and cord from motor housing.
  3. Bosch 3727DEVS Governor Replacement: adım 3, 1 resimden 1.
    • Lift the On/Off switch out of the device
    • Remove the gray and purple wires
  4. Bosch 3727DEVS Governor Replacement: adım 4, 2 resimden 1. Bosch 3727DEVS Governor Replacement: adım 4, 2 resimden 2.
    • Remove the gray, brown, and clear wires by pulling on the wire terminals.
    • Lift the Governor out of the housing.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 561
