Ana içeriğe geç
Bosch 3727DEVS Motor Brushes Replacement
Neye ihtiyacın var
  1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: adım 1, 3 resimden 1. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: adım 1, 3 resimden 2. Bosch 3727DEVS Motor Brushes  Replacement, Motor Brushes: adım 1, 3 resimden 3.
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Motor Brushes  Replacement: adım 2, 3 resimden 1. Bosch 3727DEVS Motor Brushes  Replacement: adım 2, 3 resimden 2. Bosch 3727DEVS Motor Brushes  Replacement: adım 2, 3 resimden 3.
    • Remove the two white wires connected to each motor brush by pulling on the spade terminals.
  3. Bosch 3727DEVS Motor Brushes  Replacement: adım 3, 3 resimden 1. Bosch 3727DEVS Motor Brushes  Replacement: adım 3, 3 resimden 2. Bosch 3727DEVS Motor Brushes  Replacement: adım 3, 3 resimden 3.
    • Using the T10 Torx Screwdriver, remove the four 9.7 mm screws securing the motor brushes to the housing.
    • After the screws are removed, both motor brushes can be lifted out of their position by hand.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 994
