Ana içeriğe geç
Bosch 3727DEVS Power Cord Replacement
Neye ihtiyacın var
  1. Bosch 3727DEVS Power Cord  Replacement, Power Cord: adım 1, 3 resimden 1. Bosch 3727DEVS Power Cord  Replacement, Power Cord: adım 1, 3 resimden 2. Bosch 3727DEVS Power Cord  Replacement, Power Cord: adım 1, 3 resimden 3.
    • Ensure that the power chord is not plugged into an outlet.
    • Using the T20 Torx Screwdriver, remove the four 15.6 mm screws securing the top cover to the sander.
    • Lift the top cover off the sander.
  2. Bosch 3727DEVS Power Cord  Replacement: adım 2, 3 resimden 1. Bosch 3727DEVS Power Cord  Replacement: adım 2, 3 resimden 2. Bosch 3727DEVS Power Cord  Replacement: adım 2, 3 resimden 3.
    • Using the T20 Torx Screwdriver, remove the two 15.6 mm screws securing the cable clip to the motor housing.
    • Lift cable clip and cord from motor housing.
  3. Bosch 3727DEVS Power Cord  Replacement: adım 3, 3 resimden 1. Bosch 3727DEVS Power Cord  Replacement: adım 3, 3 resimden 2. Bosch 3727DEVS Power Cord  Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Satın Al
    • Using the 2.5 mm Flathead Screwdriver, loosen the two screws securing the white and black wires to the On/Off Switch.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 442
