Ana içeriğe geç
Bosch Error Code 680
Videoya Genel Bakış
  1. Bosch Error Code 680, Remove the plates and clean everything: adım 1, 1 resimden 1.
    • Clean everything.
    • Remove the two plates with the 4 allen screws.
    FixBot'a Sor
    Yorum Ekle
  2. Bosch Error Code 680, Add a spacer on the akku: adım 2, 1 resimden 1.
    • I needed to add a little spacer direct on the akku. Because the allen screws created too much force on the akku power button.
    FixBot'a Sor
    Yorum Ekle
  3. Bosch Error Code 680, Adjust the plate on the akku: adım 3, 1 resimden 1.
    • Adjust the plate on the akku like this. Otherwise the akku could stuck when you try to mount or remove it from the bike.
    • Hint: If you loose the allen screw thread nubsis. look for the little white wholes in the akku that has scratched the black colour before. Then start with two screws and move till you catch the next one. Use a flashlight to find it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Bir başkası bu kılavuzu tamamladı.
felusch
131 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 32
Son 30 gün: 152
Her zaman: 822
