Ana içeriğe geç
Bose SoundDock Portable v2 Docking System Board Replacement
Neye ihtiyacın var
  1. Bose SoundDock Portable v2 Docking System Board Replacement, Docking System Board: adım 1, 1 resimden 1.
    • Lay the speaker flat on its back, balancing on the battery.
    • Remove the four rubber disks that cover the screws on the bottom of the speaker.
    • Follow the battery replacement guide to remove the battery
    FixBot'a Sor
    Yorum Ekle
  2. Bose SoundDock Portable v2 Docking System Board Replacement: adım 2, 1 resimden 1.
    • Now, remove the four 16mm #2 screws on the bottom of the speaker. This will allow the bottom plate to be removed.
    • It may be easier to the remove the battery so that the speaker will lay flat on the table.
    FixBot'a Sor
    Yorum Ekle
  3. Bose SoundDock Portable v2 Docking System Board Replacement: adım 3, 1 resimden 1.
    • Carefully remove the bottom panel of the speaker.
    • You may have to rock the panel back and forth to get it to slide off the plastic pegs.
    FixBot'a Sor
    Yorum Ekle
  4. Bose SoundDock Portable v2 Docking System Board Replacement: adım 4, 1 resimden 1.
    • Once the panel is removed you will see a ribbon connecting the dock to the speaker. Be careful to orient the speaker so that you can work on the dock connector without pulling on the ribbon!
    FixBot'a Sor
    Yorum Ekle
  5. Bose SoundDock Portable v2 Docking System Board Replacement: adım 5, 2 resimden 1. Bose SoundDock Portable v2 Docking System Board Replacement: adım 5, 2 resimden 2.
    • Use a T15 Torx screwdriver to remove the dock from the base. Be careful not to damage the ribbon during this step.
    • There is a torsion spring under the dock. When removed, this spring has a tendency to fly out. To avoid this, loosen the dock until it is able to move freely. Rotate it so that there is no tension in the spring. Then, you are free to undo the screw completely.
    FixBot'a Sor
    Yorum Ekle
  6. Bose SoundDock Portable v2 Docking System Board Replacement: adım 6, 2 resimden 1. Bose SoundDock Portable v2 Docking System Board Replacement: adım 6, 2 resimden 2.
    • Remove the three 6mm T8 torques screws that hold the dock connector together and pull the top and bottom pieces apart.
    • There are some small parts that may fall out when the plastic pieces are separated. To minimize this, lay the piece with the dock connector facing down.
    FixBot'a Sor
    Yorum Ekle
  7. Bose SoundDock Portable v2 Docking System Board Replacement: adım 7, 2 resimden 1. Bose SoundDock Portable v2 Docking System Board Replacement: adım 7, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Once the pieces are separated, the dock connector can be lifted out of the slot.
    • Using tweezers or your fingers, unplug the two ribbon connectors from the board.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Evan Low
584 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-1, Maness Spring 2015 Cal Poly, Team 4-1, Maness Spring 2015 üyesi
CPSU-MANESS-S15S4G1
4 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
How can I tell if it is my IPOD or the Bose system that needs to be repaired?
Ron Adams - Yanıt Paylaş
Where can I by this piece? I have to replace that piece.
PHelmut - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 28
Son 30 gün: 91
Her zaman: 23,161
