Ana içeriğe geç
Bose SoundLink Color Battery Replacement
Neye ihtiyacın var
  1. Bose SoundLink Color Battery Replacement, Outer Casing: adım 1, 2 resimden 1. Bose SoundLink Color Battery Replacement, Outer Casing: adım 1, 2 resimden 2.
    • Four round, plastic plugs are located on the back of the device.
    • Using a metal spudger, carefully pry up the plastic covers.
    • The covers are all glued on, so be careful not to scar the casing when prying them off. If possible, use a spudger or plastic opening tool to remove them.
  2. Bose SoundLink Color Battery Replacement: adım 2, 2 resimden 1. Bose SoundLink Color Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four 1.8 cm-long T15 Torx Security screws from the outer case.
    • Some of these use T15 "Star" 5-point Torx security screws instead of the more common 6-point ones.
  3. Bose SoundLink Color Battery Replacement: adım 3, 2 resimden 1. Bose SoundLink Color Battery Replacement: adım 3, 2 resimden 2.
    • Carefully open up the casing.
    • The top button pad may need to be re-glued upon installing the new casing.
  4. Bose SoundLink Color Battery Replacement, Battery: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the battery using a pair of tweezers.
    • Lift the inner assembly from the outer casing.
  5. Bose SoundLink Color Battery Replacement: adım 5, 1 resimden 1.
    • Partially cut the battery cover on the side paying attention to do not damage the circuit or the battery. Cut the cover just enough to remove it, try to not damage it too much as it is going to be reused.
  6. Bose SoundLink Color Battery Replacement: adım 6, 3 resimden 1. Bose SoundLink Color Battery Replacement: adım 6, 3 resimden 2. Bose SoundLink Color Battery Replacement: adım 6, 3 resimden 3.
    • Desolder the battery leads from the PCB and remove the battery.
  7. Bose SoundLink Color Battery Replacement: adım 7, 1 resimden 1.
    • I opted for a Panasonic NCR18650B, choose the version with solder tabs, otherwise it will be a pain to solder wires on the battery and you'll probably go out from the factory dimensions. From the benchmarks it looks like a very good battery, time will tell.
    • Fit the new battery, cut the leads to the needed length, pay attention to polarity. You may need to enlarge leads holes in the plastic case with a cutter to let standard battery leads thru.
  8. Bose SoundLink Color Battery Replacement: adım 8, 1 resimden 1.
    • Put back the sponge cover, it is necessary to avoid vibrations and to keep the thing firmly in place.
Sonuç
96 farklı kişi bu kılavuzu tamamladı.
65Kılavuz Yorumları
Any recommendations where to pick up/order a replacement battery from?
Rob Miller - Yanıt
See the link in the description, it is available thru Amazon
Giacomo di ciocco -
Has anyone found where to order battery from?
amitos80 - Yanıt
Put battery part number in google and search it on ebay. It will come up with your replacement
Ron Emerson -
Mine still works fine, but I'd like to know like the others here where to get a battery that will work as a replacement.
chandlerwebb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 363
Son 30 gün: 1,476
Her zaman: 208,178
