Giriş
If you notice any major damage to your charging port that prevents you from charging your device, you may need to replace your charging port.
Neye ihtiyacın var
Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
Gently peel back the adhesive padding on either side of the inner back panel.
Remove the two 12.5 mm screws on either side of the charging port using a Torx T10 screwdriver.
7 farklı kişi bu kılavuzu tamamladı.
13 Yorum
Hello, This is an excellent resource. One thing, you did not say, or I did not see, where to purchase the actual usb port. Where can I locate one and this would be for a Bose Soundlink II.
Thank you,
Jim
jp7868@gmail.com
HI, thanks a lot for the instructions, any idea where i acn purchase the charging port full part
thanks
Carlos
I would like to know where i can buy the replacement part
Also would love to know where to purchase the required replacement MicroUSB Port. I'm searching and if I find anything compatible I will contact anyone else who posts to this thread.
