Ana içeriğe geç
Bose SoundLink III Treble Speakers Replacement
Neye ihtiyacın var
  1. Bose SoundLink III Treble Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Use a spudger to pry the rubber pads off of the bottom panel of the SoundLink.
    • The rubber pads should have enough adhesive to stick when you reassemble them at the end. If not, however, you may need your own adhesive.
  2. Bose SoundLink III Treble Speakers Replacement: adım 2, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement: adım 2, 2 resimden 2.
    • Remove the two 12.5 mm screws using a Phillips #2 screwdriver.
    • These screws may be difficult to remove. If necessary, use a lever for extra torque.
    • Remove the bottom panel.
  3. Bose SoundLink III Treble Speakers Replacement: adım 3, 1 resimden 1.
    • Flip the rear panel back to allow access to the SoundLink's battery.
  4. Bose SoundLink III Treble Speakers Replacement: adım 4, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement: adım 4, 2 resimden 2.
    • Remove the two 12.5 mm Phillips #2 screws from the sides of the battery.
  5. Bose SoundLink III Treble Speakers Replacement, Motherboard: adım 5, 1 resimden 1.
    • Gently peel back the adhesive padding on either side of the inner back panel.
    • The adhesive for these pads is powerful, but you may require new adhesive if the original begins to fail.
  6. Bose SoundLink III Treble Speakers Replacement: adım 6, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement: adım 6, 2 resimden 2.
    • Remove the four 12.5 mm Phillips #2 screws mounting the outer case.
    • Slide off the outer case.
  7. Bose SoundLink III Treble Speakers Replacement: adım 7, 1 resimden 1.
    • Remove four screws from each of the four speakers (16 screws total) using a Torx #10 screwdriver.
    • All screws (excluding the two middle screws on the right side) are 12.5 mm in length. The aforementioned middle screws are 21 mm.
  8. Bose SoundLink III Treble Speakers Replacement: adım 8, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement: adım 8, 2 resimden 2.
    • Remove the two 12.5 mm screws which mount the top panel using a Phillips #2 screwdriver.
    • Now you should be able to lift the top panel off.
  9. Bose SoundLink III Treble Speakers Replacement: adım 9, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement: adım 9, 2 resimden 2.
    • Use a metal spudger to pry the device apart. You must use a metal spudger because of the great force necessary to pry it apart.
    • The circuitry for the buttons on the top panel may be found underneath, so use caution not to damage it.
  10. Bose SoundLink III Treble Speakers Replacement: adım 10, 1 resimden 1.
    • Remove the 12.5 mm screw mounting the motherboard using a Philips #2 screwdriver.
  11. Bose SoundLink III Treble Speakers Replacement: adım 11, 1 resimden 1.
    • Gently disconnect the three cables connected to the motherboard.
    • Remove the motherboard from the device.
  12. Bose SoundLink III Treble Speakers Replacement, Speakers: adım 12, 2 resimden 1. Bose SoundLink III Treble Speakers Replacement, Speakers: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    • For each of the 4 treble speakers you must uncoil the red wire and black wire in order to remove them.
    • You may need metal tweezers in order to re-coil the replacement speaker.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Dakoda Sanders
1.558 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Wollert Spring 2016 USF Tampa, Team 3-2, Wollert Spring 2016 üyesi
USFT-WOLLERT-S16S3G2
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Hi,
Where can i buy the replacement speakers?
Scott - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 43
Her zaman: 4,981
