Ana içeriğe geç
Bose SoundLink Mini Button Switch Circuit Board Replacement
Neye ihtiyacın var
  1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery: adım 1, 1 resimden 1.
    • Peel back the rubber battery cover and remove the four circled 6.0 mm screws using a T8 Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 2, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 2, 2 resimden 2.
    • While holding the cover back, pull straight up on the battery to remove it.
    FixBot'a Sor
    Yorum Ekle
  3. Bose SoundLink Mini Button Switch Circuit Board Replacement, Front/Back Protective Grille: adım 3, 1 resimden 1.
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
    FixBot'a Sor
    Yorum Ekle
  4. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 4, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 4, 2 resimden 2.
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
    FixBot'a Sor
    Yorum Ekle
  5. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 5, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 5, 2 resimden 2.
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
    FixBot'a Sor
    Yorum Ekle
  6. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 6, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 6, 2 resimden 2.
    • Repeat steps to remove the back grille.
    FixBot'a Sor
    Yorum Ekle
  7. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: adım 7, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement, Battery Cover: adım 7, 2 resimden 2.
    • Remove the four 15.0 mm screws on the left and the four 9.0 mm screws on the right using the T8 Torx Screwdriver.
    FixBot'a Sor
    Yorum Ekle
  8. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 8, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 8, 2 resimden 2.
    • Remove the circuit board by pushing it with your index finger in the direction shown while using a nylon or metal spudger to lift it up and out of place.
    FixBot'a Sor
    Yorum Ekle
  9. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 9, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 9, 2 resimden 2.
    • Carefully pull on the battery cover until the rubber tab slides out of the aluminum casing.
    FixBot'a Sor
    Yorum Ekle
  10. Bose SoundLink Mini Button Switch Circuit Board Replacement, Button Switch Circuit Board: adım 10, 1 resimden 1.
    • Remove the sponge (save for later replacement) and gently flip the black tab 90 degrees to release the connectors grip on the ribbon cable. Remove the ribbon cable from the connector.
    • The black tab must be flipped up in order to reinsert the ribbon cable on reassembly.
    FixBot'a Sor
    Yorum Ekle
  11. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 11, 3 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 11, 3 resimden 2. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 11, 3 resimden 3.
    • Use a Metal Spudger to pry up the plastic divider.
    FixBot'a Sor
    Yorum Ekle
  12. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 12, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 12, 2 resimden 2.
    • When removing the plastic divider be careful not to damage the wire strip sliding through it.
    FixBot'a Sor
    Yorum Ekle
  13. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 13, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 13, 2 resimden 2.
    • Reach through the battery compartment hole and unplug the power strip shown.
    FixBot'a Sor
    Yorum Ekle
  14. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 14, 3 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 14, 3 resimden 2. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 14, 3 resimden 3.
    • Remove both circuit boards by wiggling them up and out of the casing.
    • Unplug the speaker wires connected and fully remove both circuit boards.
    • When unplugging the speaker wires, squeeze the white connector piece to release the wires.
    FixBot'a Sor
    Yorum Ekle
  15. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 15, 2 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 15, 2 resimden 2.
    • Unhook the speaker wires clipped onto the button switch circuit board.
    FixBot'a Sor
    Yorum Ekle
  16. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 16, 3 resimden 1. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 16, 3 resimden 2. Bose SoundLink Mini Button Switch Circuit Board Replacement: adım 16, 3 resimden 3.
    • Use a nylon or metal spudger to slightly lift up on the button switch circuit board.
    • Pull the button switch circuit board straight out from the casing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
16 farklı kişi bu kılavuzu tamamladı.
Jordan Smith
937 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G23
4 Üyeler
24 adet Kılavuz yazıldı
12Kılavuz Yorumları
Hello
Where I can buy circuit
candellaaria - Yanıt Paylaş
Yes were can we get the replacement part? ?
sonny goddin - Yanıt Paylaş
Hi sonny,
did you find this part ? (the first circuit board)
luc.lacouture - Yanıt Paylaş
Hi
Can you get the relacement part for the mini II or is it the same - and if
- where and how to order for delivery to Europe?
Andreas Burckhart - Yanıt Paylaş
Kindly can you tell me is th bose Soundlink mini first generation has an update or not, because it started no charge and the ember ligy keep flashing and some times reed color , I bought a new battery but still the same now it’s playing up
Moqdam Aljwrany - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 65
Son 30 gün: 310
Her zaman: 40,753
