Ana içeriğe geç
Bose SoundLink Mini Front/Back Protective Grille Replacement
Neye ihtiyacın var
  1. Bose SoundLink Mini Front/Back Protective Grille Replacement, Front/Back Protective Grille: adım 1, 1 resimden 1.
    • Insert the Metal Spudger between the rubber edge on the grille and the aluminum casing.
    • Place Metal Spudger in the location shown.
  2. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 2, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 2, 2 resimden 2.
    • Slowly pry up the grille until the two tabs shown pop out.
    • Be very gentle, the grille will bend.
  3. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 3, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 3, 2 resimden 2.
    • The grille is attached to the speaker with double sided sticky tape. To remove the grill gently pull upward while keeping tension to the right.
  4. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 4, 2 resimden 1. Bose SoundLink Mini Front/Back Protective Grille Replacement: adım 4, 2 resimden 2.
    • Repeat steps to remove the back grille.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Jordan Smith
914 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-23, Maness Fall 2015 Cal Poly, Team 1-23, Maness Fall 2015 üyesi
CPSU-MANESS-F15S1G23
4 Üyeler
21 adet Kılavuz yazıldı
6 Yorum
Has anyone an idea where to buy new meshs for the dark version of Bose SL II ? My are badly scratched and I'd like to replace them.. dont know where to buy them though..
krisskuli - Yanıt
Hi brilliant advise. Where can I get hold of the front perl white grill? I can't find it anywhere!
Peter Bacher - Yanıt
Hi brilliant advise. Where can I get hold of the front perl white grill of my soundlink mini ? I can't find it anywhere!
Where can I purchase the grill?
Ronald Roden Jr - Yanıt
Take out the grills, put a peace of tape on logo properly cut it, and repaint it. Apply a thin coat of spray paint only.
Pranjal Vishwakarma - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 30
Son 30 gün: 100
Her zaman: 13,593
