Ana içeriğe geç
Bose SoundTouch Portable Motherboard Replacement
Neye ihtiyacın var
  1. Bose SoundTouch Portable Motherboard Replacement, Speaker Battery: adım 1, 1 resimden 1.
    • Remove the two T-10 machine screws at the bottom of the device.
  2. Bose SoundTouch Portable Motherboard Replacement: adım 2, 1 resimden 1.
    • Turn the device around.
    • From the top, lightly push down the back cover to release it.
    • Lift the bottom of the cover and pull it up.
  3. Bose SoundTouch Portable Motherboard Replacement: adım 3, 1 resimden 1.
    • Remove the two T-10 machine screws, then pull the battery straight out.
  4. Bose SoundTouch Portable Motherboard Replacement, Metal Trim: adım 4, 1 resimden 1.
    • Remove the two screws using a torx screwdriver.
  5. Bose SoundTouch Portable Motherboard Replacement: adım 5, 1 resimden 1.
    • With the bottom of the device facing you, pull down the trim pieces to remove from the device body.
  6. Bose SoundTouch Portable Motherboard Replacement, Motherboard: adım 6, 2 resimden 1. Bose SoundTouch Portable Motherboard Replacement, Motherboard: adım 6, 2 resimden 2.
    • Remove four T-10 Torx screws; there are two on the front and two on the back.
  7. Bose SoundTouch Portable Motherboard Replacement: adım 7, 3 resimden 1. Bose SoundTouch Portable Motherboard Replacement: adım 7, 3 resimden 2. Bose SoundTouch Portable Motherboard Replacement: adım 7, 3 resimden 3.
    • Pinch and remove the connectors.
    • Use a flat tool to pry off the top piece.
  8. Bose SoundTouch Portable Motherboard Replacement: adım 8, 3 resimden 1. Bose SoundTouch Portable Motherboard Replacement: adım 8, 3 resimden 2. Bose SoundTouch Portable Motherboard Replacement: adım 8, 3 resimden 3.
    • Remove the four T-10 Torx screws holding the plastic cover in place.
    • Remove the one T-10 Torx screw that is holding the motherboard in place.
    • Pry off the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chelsea Martin
697 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G3, Leahy Spring 2017 USF Tampa, Team S1-G3, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G3
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 2,987
