Ana içeriğe geç
Bose Soundlink Flex Battery Replacement
Neye ihtiyacın var
    1. Bose Soundlink Flex Battery Replacement, Grille: adım 1, 1 resimden 1.
      • Use a heat gun to warm up the device.
      • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
      FixBot'a Sor
      Yorum Ekle
    2. Bose Soundlink Flex Battery Replacement: adım 2, 1 resimden 1.
      • Use an iFixit opening tool to pop off the eight clips on the grille.
      • Be patient and do not rush this process as you may otherwise damage the device.
      FixBot'a Sor
      Yorum Ekle
    3. Bose Soundlink Flex Battery Replacement: adım 3, 2 resimden 1. Bose Soundlink Flex Battery Replacement: adım 3, 2 resimden 2.
      • Once the clips have been released, the only thing holding the grille on is glue.
      • Apply minimal force and the grille should pop right off the device.
      • Reheat the device to warm up the glue if there is difficulty in removing.
      FixBot'a Sor
      Yorum Ekle
    1. Bose Soundlink Flex Battery Replacement, Battery: adım 4, 3 resimden 1. Bose Soundlink Flex Battery Replacement, Battery: adım 4, 3 resimden 2. Bose Soundlink Flex Battery Replacement, Battery: adım 4, 3 resimden 3.
      • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
      • Lift the driver out, being cautious of the wires still connected to the device.
      FixBot'a Sor
      Yorum Ekle
    2. Bose Soundlink Flex Battery Replacement: adım 5, 3 resimden 1. Bose Soundlink Flex Battery Replacement: adım 5, 3 resimden 2. Bose Soundlink Flex Battery Replacement: adım 5, 3 resimden 3.
      • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
      • Pull the back panel off exposing the motherboard.
      FixBot'a Sor
      Yorum Ekle
    3. Bose Soundlink Flex Battery Replacement: adım 6, 2 resimden 1. Bose Soundlink Flex Battery Replacement: adım 6, 2 resimden 2.
      • Remove the three 1.7 mm screws from the motherboard using a TR6 Torx screwdriver.
      • Remove the single 1.4 mm screw from the motherboard using a TR5 Torx screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Bose Soundlink Flex Battery Replacement: adım 7, 3 resimden 1. Bose Soundlink Flex Battery Replacement: adım 7, 3 resimden 2. Bose Soundlink Flex Battery Replacement: adım 7, 3 resimden 3.
      • Take the motherboard out and take note of the battery attached.
      • Remove the insulation and the solder from the wiring.
      • Be careful not to damage the motherboard. Doing so will create a slew of problems for the speaker.
      • Solder the wires of the new battery onto the motherboard.
      • Be cautious when adding the solder to not damage the motherboard or burn yourself.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kalvin Lee
625 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G1
3 Üyeler
20 adet Kılavuz yazıldı
1Rehber Yorum
How do I know which one is the positive and which one is the negative side of my battery connector in soundlink flex ? As I have already removed the old battery only.
SOM SATPATHY - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 20
Son 7 gün: 88
Son 30 gün: 431
Her zaman: 8,562
