Ana içeriğe geç
Bose Soundlink Flex Grille Replacement
Neye ihtiyacın var
  1. Bose Soundlink Flex Grille Replacement, Grille: adım 1, 1 resimden 1.
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Grille Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Grille Replacement: adım 3, 2 resimden 1. Bose Soundlink Flex Grille Replacement: adım 3, 2 resimden 2.
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
Sonuç
Isaac
205 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G1
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 27
Her zaman: 196
