Ana içeriğe geç
Bose Soundlink Flex Radiator Replacement
Neye ihtiyacın var
  1. Bose Soundlink Flex Radiator Replacement, Grille: adım 1, 1 resimden 1.
    • Use a heat gun to warm up the device.
    • This will allow for an easier removal of the grille and prevent damage to the device during the replacement. If you do not have access to a heat gun, a hair dryer works as well.
  2. Bose Soundlink Flex Radiator Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pop off the eight clips on the grille.
    • Be patient and do not rush this process as you may otherwise damage the device.
  3. Bose Soundlink Flex Radiator Replacement: adım 3, 2 resimden 1. Bose Soundlink Flex Radiator Replacement: adım 3, 2 resimden 2.
    • Once the clips have been released, the only thing holding the grille on is glue.
    • Apply minimal force and the grille should pop right off the device.
    • Reheat the device to warm up the glue if there is difficulty in removing.
  4. Bose Soundlink Flex Radiator Replacement, Radiator: adım 4, 3 resimden 1. Bose Soundlink Flex Radiator Replacement, Radiator: adım 4, 3 resimden 2. Bose Soundlink Flex Radiator Replacement, Radiator: adım 4, 3 resimden 3.
    • Remove the four 2.3 mm screws holding the driver in place using a TR8 Torx screwdriver.
    • Lift the driver out, being cautious of the wires still connected to the device.
  5. Bose Soundlink Flex Radiator Replacement: adım 5, 2 resimden 1. Bose Soundlink Flex Radiator Replacement: adım 5, 2 resimden 2.
    • Remove the six 2.3 mm screws around the edge with a TR8 Torx screwdriver.
  6. Bose Soundlink Flex Radiator Replacement: adım 6, 3 resimden 1. Bose Soundlink Flex Radiator Replacement: adım 6, 3 resimden 2. Bose Soundlink Flex Radiator Replacement: adım 6, 3 resimden 3.
    • Pull the backplate off to expose both sides of the radiator.
  7. Bose Soundlink Flex Radiator Replacement: adım 7, 3 resimden 1. Bose Soundlink Flex Radiator Replacement: adım 7, 3 resimden 2. Bose Soundlink Flex Radiator Replacement: adım 7, 3 resimden 3.
    • Remove the four 2.3 mm corner screws using a TR8 Torx screwdriver.
    • Remove the two 1.7 mm screws using a TR6 Torx screwdriver.
    • Follow this step for both radiators.
  8. Bose Soundlink Flex Radiator Replacement: adım 8, 2 resimden 1. Bose Soundlink Flex Radiator Replacement: adım 8, 2 resimden 2.
    • Remove the radiator and replace with the new radiator.
Sonuç
Monica Silva
136 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-1, Shaddix Spring 2024 UMass Dartmouth, Team 4-1, Shaddix Spring 2024 üyesi
UMASSD-SHADDIX-S24S4G1
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 50
Her zaman: 287
