Ana içeriğe geç
Bose Soundlink II Side Cover Replacement
Neye ihtiyacın var
  1. Bose Soundlink II Side Cover Replacement, Bose Soundlink II Cover Removal: adım 1, 1 resimden 1.
    • Using a 2.5 mm hex wrench, remove the two 13 mm screws from the bottom of the speaker.
  2. Bose Soundlink II Side Cover Replacement: adım 2, 1 resimden 1.
    • Push up on the back of the cover until it slides up slightly.
    • Pull the cover up and away from the speaker backing.
  3. Bose Soundlink II Side Cover Replacement, Side Cover: adım 3, 1 resimden 1.
    • Remove the black electrical tape in order to reveal the screws attaching the side cover to the main body of the speaker. These screws are on the base of the device.
  4. Bose Soundlink II Side Cover Replacement: adım 4, 1 resimden 1.
    • Using the T-10 star tip screwdriver, remove the two 13 mm screws located on the bottom of the speaker on each side of the battery pack.
  5. Bose Soundlink II Side Cover Replacement: adım 5, 3 resimden 1. Bose Soundlink II Side Cover Replacement: adım 5, 3 resimden 2. Bose Soundlink II Side Cover Replacement: adım 5, 3 resimden 3.
    • Slide the silver side cover down toward the base of the speaker. The silver cover will come off easily.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
John P Loughran
472 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G3, Harley Spring 2017 IUPUI, Team S3-G3, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S3G3
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 22
Her zaman: 2,819
