Ana içeriğe geç
Bose Soundlink Mini II Speaker Guard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Bose Soundlink Mini II Speaker Guard Replacement, Speaker Guard: adım 1, 2 resimden 1. Bose Soundlink Mini II Speaker Guard Replacement, Speaker Guard: adım 1, 2 resimden 2.
    • Two mesh tabs hold the speaker guard in place on either end.
    • Use the plastic opening tool to peel away the rubber insert.
    • Use the metal spudger to lift one of the tabs away from the device.
  2. Bose Soundlink Mini II Speaker Guard Replacement: adım 2, 2 resimden 1. Bose Soundlink Mini II Speaker Guard Replacement: adım 2, 2 resimden 2.
    • Carefully peel the mesh speaker guard away from the device.
  3. Bose Soundlink Mini II Speaker Guard Replacement: adım 3, 1 resimden 1.
    • Remove the mesh tabs from the other side of the device.
  4. Bose Soundlink Mini II Speaker Guard Replacement: adım 4, 2 resimden 1. Bose Soundlink Mini II Speaker Guard Replacement: adım 4, 2 resimden 2.
    • To replace the speaker guard, make sure the rubber insert is in place on the back of the mesh guard.
    • Insert one end of the speaker guard into the frame. Then gently fit the other end of the speaker guard into the frame.
    • You will have to fit the tabs on one end into the device first, and then slightly bend the guard into the other side.
    • Press firmly on the speaker guard ensuring that it is properly installed.
Bitiş Çizgisi
7 farklı kişi bu kılavuzu tamamladı.
Jackie Dupuis
239 İtibar
1 Kılavuz yazıldı
Ekip
Texas Tech, Team 19-2, Rauch Fall 2015 Texas Tech, Team 19-2, Rauch Fall 2015 üyesi
TTU-RAUCH-F15S19G2
5 Üyeler
1 Kılavuz yazıldı
4 Yorum
Where do you buy the replacement speaker guards from? (UK)
markfrances9 - Yanıt
Where do you find a spare speaker guard for the soundlink mini 2?
My mail. "engadin@gmx.ch" regards Peter
Peter Bacher - Yanıt
Where do I find a speaker guard for soundlink mini 2 please. Regards Peter
i have a bose soundlink mini 2, oneday i left it on and left my room. on my return i found out that it has gone off and since then it cannot turn on again. i have charged it overnight, in fact i have charged it for both short and long time but still can't turn on. when i press the power button it doesn't show any sign of booting.
can you repair my bose soundlink mini 2 for me?
king fazz - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 4,891
