Ana içeriğe geç
Bose Soundlink Revolve AUX/USB Port Replacement
Neye ihtiyacın var
  1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: adım 1, 2 resimden 1. Bose Soundlink Revolve AUX/USB Port Replacement, Bottom Circuit Board Access: adım 1, 2 resimden 2.
    • Flip speaker over so that the bottom is facing up.
    • Using the blue spudger, lift the gray foam up and slowly peel it off with your hand.
  2. Bose Soundlink Revolve AUX/USB Port Replacement: adım 2, 3 resimden 1. Bose Soundlink Revolve AUX/USB Port Replacement: adım 2, 3 resimden 2. Bose Soundlink Revolve AUX/USB Port Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, unscrew three screws.
    • Detach the bottom cover from the rest of the speaker by pulling the two in opposite directions.
  3. Bose Soundlink Revolve AUX/USB Port Replacement: adım 3, 2 resimden 1. Bose Soundlink Revolve AUX/USB Port Replacement: adım 3, 2 resimden 2.
    • Remove the screw that is above the charging port.
  4. Bose Soundlink Revolve AUX/USB Port Replacement: adım 4, 2 resimden 1. Bose Soundlink Revolve AUX/USB Port Replacement: adım 4, 2 resimden 2.
    • Remove the two screws connecting the motherboard to the bottom cover of the speaker.
    • Remove the bottom cover.
  5. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: adım 5, 3 resimden 1. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: adım 5, 3 resimden 2. Bose Soundlink Revolve AUX/USB Port Replacement, AUX/USB Port: adım 5, 3 resimden 3.
    • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
    • Remove the AUX/USB port from the device.
Sonuç
15 farklı kişi bu kılavuzu tamamladı.
Brian Butner
912 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G2, Remmell Fall 2017 USF Tampa, Team S6-G2, Remmell Fall 2017 üyesi
USFT-REMMELL-F17S6G2
4 Üyeler
4 adet Kılavuz yazıldı
17Kılavuz Yorumları
Any idea where I can find the USB/Aux board for sale?
Chad - Yanıt
Did you ever manage to find a place to buy it?
Steve Fantin -
You can buy a charging cradle for this device, maybe that helps..
adsf -
Try buying the wireless charger for $29: https://www.bose.com/en_us/products/spea...
Reynolds Cameron -
I am also looking for the usb port replacement part.
James Nowicki - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 81
Son 30 gün: 325
Her zaman: 37,216
