Ana içeriğe geç
Bose Wave Radio AWR1-1W Screen Replacement
Neye ihtiyacın var
  1. Bose Wave Radio AWR1-1W Screen Replacement, Base: adım 1, 2 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement, Base: adım 1, 2 resimden 2.
    • Remove the four 19mm Phillips #2 screws from the base of the device.
  2. Bose Wave Radio AWR1-1W Screen Replacement: adım 2, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 2, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement: adım 2, 3 resimden 3.
    • Turn the device over, holding the base on with your thumbs.
    • Hold the device tightly to prevent the base from falling off.
  3. Bose Wave Radio AWR1-1W Screen Replacement: adım 3, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 3, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement: adım 3, 3 resimden 3.
    • Gently lift the top off of the device.
    • Lift in the direction shown to avoid damaging the wires connecting the top and base of the device.
  4. Bose Wave Radio AWR1-1W Screen Replacement: adım 4, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 4, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement: adım 4, 3 resimden 3.
    • Pinch and unplug the white connector from the device.
  5. Bose Wave Radio AWR1-1W Screen Replacement: adım 5, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 5, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement: adım 5, 3 resimden 3.
    • Gently pinch and pull on the white ribbon cable to disconnect it from the base.
  6. Bose Wave Radio AWR1-1W Screen Replacement: adım 6, 1 resimden 1.
    • The base should now be completely detached from the device.
  7. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: adım 7, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: adım 7, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement, Front Grill: adım 7, 3 resimden 3.
    • Wedge the spudger between the top and front panel on the right side of the device.
    • Push down on the spudger, lifting the front panel away from the top panel until it pops out of the right side.
    • Repeat for the left side of the device.
    • Too much pressure may break the panel, but it should flex slightly before it pops out.
  8. Bose Wave Radio AWR1-1W Screen Replacement: adım 8, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 8, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement: adım 8, 3 resimden 3.
    • Once the panel is released on the left side, wedge the spudger between the top panel and front grill of the device as shown.
    • Apply pressure and move the spudger upward until the front grill pops out.
    • Repeat for the right side of the device.
  9. Bose Wave Radio AWR1-1W Screen Replacement: adım 9, 1 resimden 1.
    • Lift the front grill away from the device.
  10. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: adım 10, 2 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement, Button Panel: adım 10, 2 resimden 2.
    • Turn the device around.
    • Wedge the spudger into the larger part of the gap under the back of the device.
  11. Bose Wave Radio AWR1-1W Screen Replacement: adım 11, 1 resimden 1.
    • Move the spudger up until the button panel is loose.
    • Push forward on the back of the button panel to disconnect the panel from the top of the device.
  12. Bose Wave Radio AWR1-1W Screen Replacement: adım 12, 2 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 12, 2 resimden 2.
    • Pull the button panel forward with one hand and push the screen assembly into the device with the other to disconnect the button panel.
  13. Bose Wave Radio AWR1-1W Screen Replacement, Screen: adım 13, 3 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement, Screen: adım 13, 3 resimden 2. Bose Wave Radio AWR1-1W Screen Replacement, Screen: adım 13, 3 resimden 3.
    • Gently pull the top of the screen assembly away from the device.
  14. Bose Wave Radio AWR1-1W Screen Replacement: adım 14, 2 resimden 1. Bose Wave Radio AWR1-1W Screen Replacement: adım 14, 2 resimden 2.
    • Lift the screen assembly upward and pull the white wire strip out of the device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Cassie Harriman
1.033 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S15-G2, Banghart Spring 2017 Cal Poly, Team S15-G2, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S15G2
4 Üyeler
6 adet Kılavuz yazıldı
5 Yorum
Great! This device is the best wave system in sound accurate. All frequencies sounds clear!!! Awesome!!!
srmrs - Yanıt
Nicely done.  Love the details.  Just one question - where can I get the replacement screen?
Patsy Hamilton - Yanıt
Instructions were PERFECT! Thank you. I found my replacement screen on ebay for $25, took a chance that it would work as stated by the seller. Otherwise I would have thrown the radio away.
John Stine - Yanıt
I performed the repair as directed. It was easy especially if you have a plastic spung to work with. Problem comes from the new display once installed shows all the characters? Unplugged it and re-plugged but still stuck in all character test mode?
plhamp - Yanıt
How to purchase White wire strip
Bruce Ebneter - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 67
Her zaman: 10,261
