Ana içeriğe geç
Bose-301 Series II Tweeter Replacement
Neye ihtiyacın var
  1. Bose-301 Series II Tweeter Replacement, Tweeter: adım 1, 3 resimden 1. Bose-301 Series II Tweeter Replacement, Tweeter: adım 1, 3 resimden 2. Bose-301 Series II Tweeter Replacement, Tweeter: adım 1, 3 resimden 3.
    • Begin the repair by placing the Bose-301 speaker vertically.
    • Using two hands, pull the speaker grill towards you and away from the speaker body.
  2. Bose-301 Series II Tweeter Replacement: adım 2, 1 resimden 1.
    • Pull the main speaker grill towards you to remove it from the body structure.
  3. Bose-301 Series II Tweeter Replacement: adım 3, 3 resimden 1. Bose-301 Series II Tweeter Replacement: adım 3, 3 resimden 2. Bose-301 Series II Tweeter Replacement: adım 3, 3 resimden 3.
    • Lay the speaker body on its back.
    • Using the Philips Screwdriver, carefully remove the four #2x19mm screws that mount the main speaker to the speaker body.
  4. Bose-301 Series II Tweeter Replacement: adım 4, 2 resimden 1. Bose-301 Series II Tweeter Replacement: adım 4, 2 resimden 2.
    • Untwist the slack in the wires that are connected to the main speaker.
  5. Bose-301 Series II Tweeter Replacement: adım 5, 3 resimden 1. Bose-301 Series II Tweeter Replacement: adım 5, 3 resimden 2. Bose-301 Series II Tweeter Replacement: adım 5, 3 resimden 3.
    • Carefully place the speaker off to the side.
    • Be sure to not place the speaker face down or put pressure on the speaker cone as this can damage the cone.
    • Be aware of the very strong magnet in the driver of the speaker, which can cause damage to electronic devices in close proximity.
    • Then untwist the slack in the wires that are connected to the tweeters.
  6. Bose-301 Series II Tweeter Replacement: adım 6, 1 resimden 1.
    • Using the socket wrench and the 1/4" socket, unscrew the 12.5 mm bolt that mounts the tweeter to the bracket.
  7. Bose-301 Series II Tweeter Replacement: adım 7, 1 resimden 1.
    • While holding the tweeter, use your other hand to feed the wire through the hole at the bottom of the tweeter mount.
  8. Bose-301 Series II Tweeter Replacement: adım 8, 2 resimden 1. Bose-301 Series II Tweeter Replacement: adım 8, 2 resimden 2.
    • Remove the tweeter from the mount and locate the two wires that connect it to the speaker.
    • Using the pliers, untwist the wires that are attached to the two small rods at the bottom of the tweeter.
    • Repeat process for the second tweeter.
    • Be sure not to excessively bend the bare wires in order to reuse it for the replacement tweeters.
Sonuç
To reassemble your speaker, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Patrick Emery
174 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 15-3, Remmell Spring 2017 USF Tampa, Team 15-3, Remmell Spring 2017 üyesi
USFT-REMMELL-S17S15G3
4 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 64
Her zaman: 7,125
