Ana içeriğe geç
Bougies Peugeot 306 vervangen
Neye ihtiyacın var
  1. Bougies Peugeot 306 vervangen, introductie: adım 1, 3 resimden 1. Bougies Peugeot 306 vervangen, introductie: adım 1, 3 resimden 2. Bougies Peugeot 306 vervangen, introductie: adım 1, 3 resimden 3.
    • Open de motorkap van de auto met de hendel linksonder op het dashboard, vlakbij de pedalen.
    • Localiseer de accu van de auto en koppel deze los.
  2. Bougies Peugeot 306 vervangen, Ignition Coil Connector (Part 1): adım 2, 2 resimden 1. Bougies Peugeot 306 vervangen, Ignition Coil Connector (Part 1): adım 2, 2 resimden 2.
    • Identify the ignition coil pack connector.
  3. Bougies Peugeot 306 vervangen, Ignition Coil Connector (Part 2): adım 3, 3 resimden 1. Bougies Peugeot 306 vervangen, Ignition Coil Connector (Part 2): adım 3, 3 resimden 2. Bougies Peugeot 306 vervangen, Ignition Coil Connector (Part 2): adım 3, 3 resimden 3.
    • Press the locking rod near the bottom to release the connector.
    • Disconnect the ignition coil connector.
  4. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 1): adım 4, 3 resimden 1. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 1): adım 4, 3 resimden 2. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 1): adım 4, 3 resimden 3.
    • Locate the six H4 screws on the ignition coil pack.
    • Use an H4 (or T30) screwdriver to unscrew the six screws.
  5. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 2): adım 5, 3 resimden 1. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 2): adım 5, 3 resimden 2. Bougies Peugeot 306 vervangen, Remove the ignition coil pack (Part 2): adım 5, 3 resimden 3.
    • Grip the ignition coil pack on both sides and pull it directly upwards to remove it.
  6. Bougies Peugeot 306 vervangen, Disassemble the spark plugs: adım 6, 3 resimden 1. Bougies Peugeot 306 vervangen, Disassemble the spark plugs: adım 6, 3 resimden 2. Bougies Peugeot 306 vervangen, Disassemble the spark plugs: adım 6, 3 resimden 3.
    • Locate the four spark plug chambers.
    • Grab a spark plug wrench (size 16mm).
    • Insert the wrench into the first spark plug chamber, until you reach the bolt.
    • Certain spark plug wrench are equipped with a rubber joint to help with extracting the spark plug. It is therefore necessary to apply light pressure to correctly reach the spark plug's bolt.
    • Unscrew the first spark plug, remove it from its chamber.
    • Continue in the same manner for the other three spark plugs.
  7. Bougies Peugeot 306 vervangen, Clean and replace the spark plugs: adım 7, 2 resimden 1. Bougies Peugeot 306 vervangen, Clean and replace the spark plugs: adım 7, 2 resimden 2.
    • You can now proceed to clean or replace the spark plugs.
    • The cleaning of a spark plug can be done with contact cleaner and a brass brush.
    • To reinstall the spark plugs, repeat this procedure in reverse.
    • When reinstalling, be sure to rest the spark plug as straight as possible, to align the thread axes of each spark plug. The recommended tightening torque is 29Nm (21.4 lbft)
Sonuç
Om alles weer in elkaar te zetten, volg je de instructies in omgekeerde volgorde.
9 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
fr en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Subject42
2.828 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 90
Son 30 gün: 589
Her zaman: 13,452
