Ana içeriğe geç
Bowers and Wilkins P5 Headphones Driver Replacement
Neye ihtiyacın var
  1. Bowers and Wilkins P5 Headphones Driver Replacement, Driver: adım 1, 1 resimden 1.
    • Remove the earpads from your P5s.
    • Removed driver in centre.
  2. Bowers and Wilkins P5 Headphones Driver Replacement: adım 2, 1 resimden 1.
    • Each side uses three Phillips screws, which are covered in fabric. You can either gently scrape away the fabric in the areas indicated, or insert your driver directly. I did the former but it can bunch up the fabric.
    • This is the right side.
  3. Bowers and Wilkins P5 Headphones Driver Replacement: adım 3, 1 resimden 1.
    • This is the left side.
  4. Bowers and Wilkins P5 Headphones Driver Replacement: adım 4, 2 resimden 1. Bowers and Wilkins P5 Headphones Driver Replacement: adım 4, 2 resimden 2.
    • Gently flip each driver area to the side - it will still be connected to the headband with two soldered wires.
    • De-solder each wire to fully separate the driver area. (Already completed and driver removed in this step.)
  5. Bowers and Wilkins P5 Headphones Driver Replacement: adım 5, 1 resimden 1.
    • The drivers are inconveniently glued in place, but can be relatively easily removed with some elbow grease.
    • I used an iOpener to soften the glue, along with a Jimmy and metal spudger to score the glue around the circumference.
    • Each driver area has a cutout section, as indicated, which will assist you with prying out the driver.
    • Try to work the driver out only by its sides. I pushed my metal spudger underneath and pried upward and damaged the driver grille.
  6. Bowers and Wilkins P5 Headphones Driver Replacement: adım 6, 1 resimden 1.
    • Swap the working driver from one set to the other set and solder it in place.
    • Voila!
Sonuç
To reassemble your device, follow these instructions in reverse order and solder the new driver back in place.
Bir başkası bu kılavuzu tamamladı.
Jon
633 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 64
Her zaman: 3,087
