Ana içeriğe geç
Bowers and Wilkins T7 Speaker Driver Replacement
Neye ihtiyacın var
  1. Bowers and Wilkins T7 Speaker Driver Replacement, Access Panel: adım 1, 1 resimden 1.
    • As with all electronic devices, make sure your device is powered off before you begin.
    • Gently lift up the access panel; it should easily "pop" open.
  2. Bowers and Wilkins T7 Speaker Driver Replacement: adım 2, 1 resimden 1.
    • Remove 14mm screws on the front panel with a J1 Phillips head screwdriver.
    • There are 8 screws in total.
  3. Bowers and Wilkins T7 Speaker Driver Replacement: adım 3, 2 resimden 1. Bowers and Wilkins T7 Speaker Driver Replacement: adım 3, 2 resimden 2.
    • Be gentle, the rubber seal is fragile and easy to tear, resulting in cosmetic damage to your device.
    • Using the ifixit Opening Tool, carefully pry off the rubber seal around the sides.
    • The seal is held by adhesive, if this is proving difficult you can use a heat gun to help the process.
  4. Bowers and Wilkins T7 Speaker Driver Replacement: adım 4, 2 resimden 1. Bowers and Wilkins T7 Speaker Driver Replacement: adım 4, 2 resimden 2.
    • The cover is the most difficult part to remove. As you work, pry continuously, moving the tool around the device, working it a little further as you go.
    • Using the ifixit Opening Tool, pry open at the seam found under the rubber seal.
    • As the cover starts to come off, you can lift up using your hand.
  5. Bowers and Wilkins T7 Speaker Driver Replacement: adım 5, 3 resimden 1. Bowers and Wilkins T7 Speaker Driver Replacement: adım 5, 3 resimden 2. Bowers and Wilkins T7 Speaker Driver Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
    • While squeezing the internal locking mechanism, pull back the terminal.
    • Repeat this process for the second speaker.
  6. Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: adım 6, 2 resimden 1. Bowers and Wilkins T7 Speaker Driver Replacement, Speaker Driver: adım 6, 2 resimden 2.
    • Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
    • There are 4 screws in total around each speaker.
  7. Bowers and Wilkins T7 Speaker Driver Replacement: adım 7, 1 resimden 1.
    • Now that all the screws are removed, pull straight up on the speaker drive to remove the speaker drive component.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
USF Tampa, Team S7-G1, Cagle Spring 2017 USF Tampa, Team S7-G1, Cagle Spring 2017 üyesi
USFT-CAGLE-S17S7G1
5 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where do you buy the replacement driver?
nigellittledesignandmedia - Yanıt
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
Phương Trần - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 31
Her zaman: 2,288
