Giriş
Use this guide to learn how to replace your left and right speaker drivers for the Bowers and Wilkins T7 Bluetooth Speaker.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
Gently squeeze the internal locking mechanism inside the red and white terminals with either your fingers or a pair of precision tweezers.
While squeezing the internal locking mechanism, pull back the terminal.
Repeat this process for the second speaker.
Remove the 7mm screws around the speaker using a J100 Phillips head screwdriver.
There are 4 screws in total around each speaker.
2 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where do you buy the replacement driver?
Tôi có cùng một câu hỏi? Tôi sẽ phải mua chúng ở đâu.
