Ana içeriğe geç
Braun 5514 Motor Replacement
Neye ihtiyacın var
  1. Braun 5514 Motor Replacement, Motor: adım 1, 1 resimden 1.
    • Remove any attached trimmer heads by gripping and pulling away from the body.
  2. Braun 5514 Motor Replacement: adım 2, 3 resimden 1. Braun 5514 Motor Replacement: adım 2, 3 resimden 2. Braun 5514 Motor Replacement: adım 2, 3 resimden 3.
    • Insert an opening pick between the top plate and the grey separator.
    • Slide the opening pick around the perimeter of the plate to release the hidden clips.
  3. Braun 5514 Motor Replacement: adım 3, 1 resimden 1.
    • Remove the four 7mm Torx T6 screws attaching the grey plastic frame to the black plastic casing.
  4. Braun 5514 Motor Replacement: adım 4, 2 resimden 1. Braun 5514 Motor Replacement: adım 4, 2 resimden 2.
    • Use the opening pick to lift the grey frame from the black casing.
  5. Braun 5514 Motor Replacement: adım 5, 2 resimden 1. Braun 5514 Motor Replacement: adım 5, 2 resimden 2.
    • Remove the circuit board assembly from the frame.
  6. Braun 5514 Motor Replacement: adım 6, 1 resimden 1.
    • Pull the small black plastic piece out of the frame.
  7. Braun 5514 Motor Replacement: adım 7, 2 resimden 1. Braun 5514 Motor Replacement: adım 7, 2 resimden 2.
    • Desolder the wires attached to the motor.
    • Remember where the red and black wires attach in case the replacement motor doesn't have it labeled.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew Kluckhuhn
1.087 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Summer 2018 IUPUI, Team S2-G2, Harley Summer 2018 üyesi
IUPUI-HARLEY-SU18S2G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 26
Son 30 gün: 80
Her zaman: 3,587
