Ana içeriğe geç
Braun Aromaster KF440 Base Replacement
Neye ihtiyacın var
  1. Braun Aromaster KF440 Base Replacement, Access the base: adım 1, 1 resimden 1.
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 Base Replacement, Remove the nut: adım 2, 1 resimden 1.
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 Base Replacement, Remove the cover: adım 3, 1 resimden 1.
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
Sonuç
Darcy Groom
343 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G12
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Can’t remove nut. Soooo small. Plus, clockwise… Or counter clockwise?
Bobbie Savitz - Yanıt
Das Problem istnicht die das Entfernen der Mutter wie beschrieben, sondern die Schraube die nur mit einem Spezial-Schraubenzieher geloesst werden kann. Und den gibts nicht zu kaufen. Oder?
Udo Doerge - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 3,084
