Ana içeriğe geç
Braun Aromaster KF440 Filter Basket Replacement Guide
Neye ihtiyacın var
  1. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the carafe.: adım 1, 1 resimden 1.
    • Remove the carafe from the coffee maker.
    • Set the carafe aside.
  2. Braun Aromaster KF440 Filter Basket Replacement Guide, Open the filter basket.: adım 2, 1 resimden 1.
    • Grab the ridge on the left side of the coffee maker.
    • Rotate the filter basket to the right.
  3. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket housing.: adım 3, 1 resimden 1.
    • Grab the filter basket firmly and lift upwards. You may need to use one hand to hold the body of the coffee maker in place in order to remove the piece.
  4. Braun Aromaster KF440 Filter Basket Replacement Guide, Loosen the filter basket from its housing.: adım 4, 1 resimden 1.
    • Wedge the plastic opening tool between the filter basket and its housing.
    • Be sure to wedge the tools close to the tab on the right side of the housing.
    • Wiggle tools to loosen the housing from the filter basket.
  5. Braun Aromaster KF440 Filter Basket Replacement Guide, Remove the filter basket from its housing.: adım 5, 1 resimden 1.
    • Once the filter basket has been pried loose, grab the filter basket and lift it out of the housing.
Sonuç
Darcy Groom
343 İtibar
3 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G12
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
How do you replace the pin in between the coffee carafe and water basket??
janfinochio - Yanıt
Put the upper hinge first, slide it in and lower to put the back one in. Check this video if in doubt: https://www.youtube.com/watch?v=FP5dKQqD...
Andrés Boza Arce -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 58
Her zaman: 5,812
