Ana içeriğe geç
Braun Aromaster KF440 one-way valve Replacement
Neye ihtiyacın var
  1. Braun Aromaster KF440 one-way valve Replacement, Access the base: adım 1, 1 resimden 1.
    • Remove the carafe (coffee pot) from the coffee maker.
    • Turn the Braun Aromaster KF 440 upside down so the base is exposed.
  2. Braun Aromaster KF440 one-way valve Replacement, Remove the nut: adım 2, 1 resimden 1.
    • Locate the nut at the center of the base and unscrew it with a pair of basic pliers.
  3. Braun Aromaster KF440 one-way valve Replacement, Remove the cover: adım 3, 1 resimden 1.
    • Gently lift the cover away from the bottom of the coffee maker and remove it.
  4. Braun Aromaster KF440 one-way valve Replacement, Locate internal one-way valve: adım 4, 1 resimden 1.
    • Locate the one-way valve.
  5. Braun Aromaster KF440 one-way valve Replacement, Pull out valve: adım 5, 1 resimden 1.
    • Lift up on the one way valve to snap it out of place. (This shouldn't require much force).
  6. Braun Aromaster KF440 one-way valve Replacement, Push tube off the one-way valve: adım 6, 1 resimden 1.
    • Using the larger plastic opening tool, gently push the tubing off of the one-way valve. (If the tubing is being stubborn and won't come off, run the metal spudger around the inside of tubing to free it up.)
  7. Braun Aromaster KF440 one-way valve Replacement, Lift valve: adım 7, 1 resimden 1.
    • Completely remove one-way valve from the inside of the coffee maker.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Dennis
315 İtibar
2 adet Kılavuz yazıldı
Ekip
Baylor, Team 8-12, Williams Fall 2014 Baylor, Team 8-12, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S8G12
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 25
Her zaman: 3,272
