Giriş
Use this guide to remove and replace the batteries in the Braun Cruzer 6 - Beard and Hair Trimmer, Model: 5417
Remove the trimmer head.
Remove the two Torx T5 screws attaching the cover to the hand-piece.
Remove the cover.
Take this opportunity to remove built up hair and residue. Hair can prevent the batteries from making contact leading to power failure.
Remove the back cover.
Using a flat head screw driver, remove the single screw holding the power board in place.
Use compressed air to clean the motor. Take this opportunity to lubricate the trimmer with an anti-rust spray or WD-40.
Remove the two AAA batteries by soldering them with soldering iron and des soldering pump.
Bend the terminals of the new batteries and solder them back in the right direction
If the batteries are already slightly charged, you can briefly press the power button to check if the motor is working
Insert the board again, with the side towards the motor first
22 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
5 Comments
Your guide saved me from purchasing a new device.
After replacing the batteries it works again like a charm!
Thanks this was helpful. The Braun Series 3 Hair Clipper HC3050 has a VERY similar design. Some additional notes: After removing the screws, it takes a bit of force to get the back separated from the front. I had to gently pry it apart with a screw driver. The very inside is slightly different, but same concept.
Die Anleitung war sehr hilfreich.
Der Austausch der Batterien ging ziemlich gut.
I think one pcc— 1.2 V 1800 mah AA battary
Thank you! Another appliance reborn :)
It really helps to work around consumerism with such shared knowledge!
Keep it up 👍
