Ana içeriğe geç
Braun Oral-B Sonic Complete 4729 Battery Replacement
Neye ihtiyacın var
  1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: adım 1, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: adım 1, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Opening the bottom lid: adım 1, 3 resimden 3.
    • Take the device and place it on top of its charger.
    • Now hold down firmly the charger and pull the top of the toothbrush backwards.
    • Just above the lid there is the induction coil, so don't pull too much, or it could get damaged!
    • When the lid at the bottom opens, stop pulling and take it off manually
  2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: adım 2, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: adım 2, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Pull of the water protection ring: adım 2, 3 resimden 3.
    • Take the screwdriver (or the plastic opening tool) and go under the ring at the top of the gummed area.
    • Now rotate it slightly so the ring comes loose.
    • Be careful not to damage the gum under the ring, as it assures that no water gets inside!
  3. Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: adım 3, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: adım 3, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Take out the interior: adım 3, 3 resimden 3.
    • Push the point of the device down onto the table and take out the inside.
  4. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): adım 4, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): adım 4, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 1): adım 4, 3 resimden 3.
    • First take away the metal sheet of the start/stop button.
    • Then pull the center of the black metal connection of the pressure sensor slightly upwards until the hook holding it to the sensor comes loose.
    • Now it has to be desoldered from the logic board.
  5. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): adım 5, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): adım 5, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 2): adım 5, 3 resimden 3.
    • Now you have to desolder the sensor connection and both the connections to the red led at the top.
    • The white plastic pins left and right to the led connections can easily melt!
    • Then desolder the connections to the charging coil.
    • Be careful not to touch nearby electronic components, as they could get damaged!
    • And keep the soldering time short and remove the soldering iron as soon as the solder has become liquid, so there is no overheating risk!
  6. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): adım 6, 3 resimden 1. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): adım 6, 3 resimden 2. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): adım 6, 3 resimden 3.
    • First pull off the white plastic support for the red led.
    • Then push the plastic casing of the battery together to pull of the coil.
  7. Braun Oral-B Sonic Complete 4729 Battery Replacement, Clearing the way for the battery (Part 3): adım 7, 1 resimden 1.
    • Now the connections to the motor have to be desoldered to take the battery casing of.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
TheFixaholic
573 İtibar
2 adet Kılavuz yazıldı
2 Yorum
A good guide but I found removing the bottom quite troublesome. Levering against the charging base felt like it would break the base. I needed to lever it in stages, wedge it and grab and pull it with mole grips. This damaged the plastic a little, but I got it off.
Cone - Yanıt
Hmm, maybe they changed the construction. When I created the guide the bottoms (of the 2 toothbrushes I repaired) opened quite easily, but that's good to know.
Also I do not think you need to worry about breaking the base: as most chargers that you plug in the mains, it should be completely filled with a hard resin, and thus be almost indestructible.
TheFixaholic -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 32
Son 30 gün: 151
Her zaman: 6,879
