Ana içeriğe geç
Braun Series 7 790cc-7 Battery Replacement
Neye ihtiyacın var
  1. Braun Series 7 790cc-7 Battery Replacement, Battery: adım 1, 2 resimden 1. Braun Series 7 790cc-7 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use a spudger to remove the rubber piece on the back of the razor.
  2. Braun Series 7 790cc-7 Battery Replacement: adım 2, 1 resimden 1.
    • Use a Torx T8 to remove (4) 10 mm screws from housing.
  3. Braun Series 7 790cc-7 Battery Replacement: adım 3, 2 resimden 1. Braun Series 7 790cc-7 Battery Replacement: adım 3, 2 resimden 2.
    • Remove the rear cover from the device.
  4. Braun Series 7 790cc-7 Battery Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the holster inside the device.
  5. Braun Series 7 790cc-7 Battery Replacement: adım 5, 1 resimden 1.
    • Replace the battery with a new 1300 mAh Sanyo (UR18500Y) battery.
    • Be sure to insert the battery the correct way.
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
Alex Speer
1.003 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Fall 2017 IUPUI, Team S3-G6, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G6
3 Üyeler
9 adet Kılavuz yazıldı
28Kılavuz Yorumları
Where do you buy the Battery?
bruce Forsyth - Yanıt
Any idea on how to remove/replace the drive unit? I bought a new one but the plastic backing is extremely hard to get off.
Chris - Yanıt
Thank you for the awesome tutorial Alex!
I just wanted to comment that a small flat-head screw driver can be used to remove the 4 screws (under the rubber handle piece) if you don’t have a Torx tool. The screws each have 1 small slot across the head and if you’re careful you can remove and re-install them without too much trouble.
Thanks again for helping to save me a lot of trouble with this Alex… and avoid having to buy a new electric razor!
-jb-
arcticassault - Yanıt
How do you reset the battery life indicator on the shaver after replacement?
jclemis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 153
Son 30 gün: 880
Her zaman: 63,677
