Ana içeriğe geç
Braun Series 7 790cc-7 Charging Base Wire Harness Replacement
Neye ihtiyacın var
  1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement, Charging base wire harness: adım 1, 1 resimden 1.
    • Remove the cleaner cartridge from the charging base.
  2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 2, 3 resimden 1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 2, 3 resimden 2. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 2, 3 resimden 3.
    • Depress the 4 tabs while lightly pulling the cover from the base.
    • Next, depress the 2 molded tabs while still pulling the cover from the base.
  3. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 3, 1 resimden 1.
    • Press inward on the side charging port while pulling cover from the base to separate.
  4. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 4, 2 resimden 1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 4, 2 resimden 2.
    • Remove side charging port by prying tabs outward and rotating port upward.
  5. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 5, 2 resimden 1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 5, 2 resimden 2.
    • Remove charging terminals by inserting a spudger from bottom the and sliding terminals up.
  6. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 6, 2 resimden 1. Braun Series 7 790cc-7 Charging Base Wire Harness Replacement: adım 6, 2 resimden 2.
    • Remove solder from circuit board and remove charging harness.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Ian Hayes
216 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G6, Harley Fall 2017 IUPUI, Team S3-G6, Harley Fall 2017 üyesi
IUPUI-HARLEY-F17S3G6
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 1,071
