Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Take out the two 32.3 mm Phillips #1 screws from the outside.
Take out the one 6.0 mm Phillips #1 screw.
Take out the last outside screw, a 6.0 mm PH #1, to remove the grid.
Take out the 14.6 mm Flathead screws that hold the power cord in place.
Take out the 18.2 mm Flathead screws that hold the buttons in place.
Take out the 27.1 mm Flathead screws that keep the motor in place.
Loosen the 2 flathead screws in the terminal block closest to the power cord.
Pull out the power cord.
Loosen the flathead screws and remove the wires from the button holder. Remove the button holders. When you unscrew the wire opposite to where the yellow wire is connected, you can slide the button off of the middle wire connected to the motor.
Remove the flathead screws from the back of the motor.
