Ana içeriğe geç
Braven BRV-1M Button Register Replacement
Neye ihtiyacın var
  1. Braven BRV-1M Button Register Replacement, Outer Casing: adım 1, 1 resimden 1.
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
    FixBot'a Sor
  2. Braven BRV-1M Button Register Replacement: adım 2, 1 resimden 1.
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
    FixBot'a Sor
  3. Braven BRV-1M Button Register Replacement: adım 3, 1 resimden 1.
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
    FixBot'a Sor
  4. Braven BRV-1M Button Register Replacement: adım 4, 1 resimden 1.
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
    FixBot'a Sor
  5. Braven BRV-1M Button Register Replacement, Motherboard: adım 5, 1 resimden 1.
    • To remove the motherboard, proceed to unscrew the 3 Phillips #00 bit type, 13mm long screws located on both sides of the motherboard.
    FixBot'a Sor
  6. Braven BRV-1M Button Register Replacement: adım 6, 1 resimden 1.
    • Then, proceed to unscrew the 5 Phillips #00 bit type, 9mm long screws located on the face of the charging dock.
    FixBot'a Sor
  7. Braven BRV-1M Button Register Replacement: adım 7, 1 resimden 1.
    • Disconnect the two 4-pin auxiliary button register cables connected on both sides of the motherboard.
    FixBot'a Sor
  8. Braven BRV-1M Button Register Replacement: adım 8, 1 resimden 1.
    • Once disconnected, carefully remove the motherboard by pulling upwards.
    FixBot'a Sor
  9. Braven BRV-1M Button Register Replacement, Button Register: adım 9, 1 resimden 1.
    • To remove the button registers, unscrew the two Phillips #00 bit type, 6 mm screws found on both sides of the control registers.
    FixBot'a Sor
  10. Braven BRV-1M Button Register Replacement: adım 10, 1 resimden 1.
    • Carefully remove the control registers from the housing of the device.
    FixBot'a Sor
Sonuç
Erik Oliva
607 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G1
4 Üyeler
1Rehber Yorum
Great guide! Do you know the spec/name of the button registers so that I can purchase a new one to replace a dysfunctional one?
Mason McElvain - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 57
Her zaman: 612
