Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
Having a damaged outer casing can allow foreign material to enter the speaker. By following this guide, one can learn how to remove and replace the outer case of the device.
Parçalar
Hiçbir parça belirtilmedi.
  1. To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
    • To remove the outer casing, use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides of the device.
  2. Using the Metal Spudger, carefully pry  each side of the rubber casing away from the device.
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
    • To remove the inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the top side of the device.
  4. Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
    • Carefully lift away the housing and replace the broken casing/component. Replace using the new casing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Erik Oliva
607 İtibar
6 adet Kılavuz yazıldı
Takım
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 246
