Ana içeriğe geç
Braven BRV-1M Sub-woofer Cone Replacement
Neye ihtiyacın var
  1. Braven BRV-1M Sub-woofer Cone Replacement, Sub-woofer Cone: adım 1, 1 resimden 1.
    • To remove the outer rubber casing use a 3mm Hex bit to remove the 4 large 12mm Hex screws on both sides, found on the bottom part of the device.
  2. Braven BRV-1M Sub-woofer Cone Replacement: adım 2, 1 resimden 1.
    • Using the Metal Spudger, carefully pry each side of the rubber casing away from the device.
    • A little resistance should be felt, but not enough to bend the spudger.
  3. Braven BRV-1M Sub-woofer Cone Replacement: adım 3, 1 resimden 1.
    • To remove the hard inner plastic casing, use a Phillips #00 head bit to remove the 16 small 9mm screws surrounding the subwoofer on the top side of the device.
  4. Braven BRV-1M Sub-woofer Cone Replacement: adım 4, 1 resimden 1.
    • Carefully lift away the broken sub-woofer plate of the device. Replace with functioning sub-woofer plate.
Sonuç
Erik Oliva
607 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G1, Eyestone Spring 2018 USF Tampa, Team S2-G1, Eyestone Spring 2018 üyesi
USFT-EYESTONE-S18S2G1
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 190
