Ana içeriğe geç
Braven BRV-1s Outer Casing Replacement
Neye ihtiyacın var
  1. Braven BRV-1s Outer Casing Replacement, Outer Casing: adım 1, 1 resimden 1.
    • To remove the outer case, remove 4 phillips screws (Phillips #00 headtype, 9.3mm long)
  2. Braven BRV-1s Outer Casing Replacement: adım 2, 1 resimden 1.
    • Using a metal spudger, gently pry the side of the defective case.
  3. Braven BRV-1s Outer Casing Replacement: adım 3, 1 resimden 1.
    • Still using the metal spudger, continue to work your way around the outer case.
  4. Braven BRV-1s Outer Casing Replacement: adım 4, 1 resimden 1.
    • Remove the broken outer case. Replace with used/new out case.
    • Note that unless properly sealed with glue, the speaker will no longer be water resistant.
Sonuç
Cody Sprague
101 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S2-G2, Harley Spring 2017 IUPUI, Team S2-G2, Harley Spring 2017 üyesi
IUPUI-HARLEY-S17S2G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 13
Her zaman: 1,114
